T
The First Don
Heres the deal...
I've got a Boss Br-532 digital four track, a Digitech RP-12 effects board, a Dr. Rhythm 600, and Sound Forge 6.0.
I don't have an amp so I have to record everything d/l.
The Br-532 has 8 virtual tracks for each of the 4 tracks. So I can record as many overdubs as I want.
The RP-12 has a 4 band digital EQ (the frequencies are adjustable.) It has a cabinet emulator, a good amount of different effects, and compression.
Sound forge has a 20 band Graphic EQ, a 4 band Paragraphic EQ, and a Parametric EQ. It also has a compresser, and effects.
Does anyone have any production tips on how to get a somewhat quality sound with this setup? The drum machine already sounds ok. I can't figure out how to get the bass and other guitars to sit well in the mix.
So far I've tried Panning two rhythm guitars left and right and putting the lead down the center, over dubbing the lead on the chorus panned left and right.
When It comes out of the chorus it sounds like it is missing something.
I need tips on:
levels (in the mixing)
panning
EQ
overdubbing
I need tips on:
panning
EQ
overdubbing
