B
Beck
Guest
In just a few short weeks I’ve been duped twice buying from eBay sellers who have obviously resealed a product in plastic to make it look new. Either that or they bought it from someone else that way, so they were also misled.
The first item was a half-inch reel of Ampex by Quantegy 456. On one side of the plastic around the reel the seal left a non-standard imprint that I’ve never seen. I’ve been through enough tape in my lifetime to catch the most minuet details. Upon opening the bag the tape pancake was totally loose on the reel, flopping back and forth like it wasn’t wound properly. This is an indication the tape had been baked. If someone doesn’t rewind a tape after baking it will be unusually loose like this because the wind loosens as the moisture is evaporated from the tape. You will regularly see uneven winding in brand new tape from storage and transport, but a floppy wind due to baking is much different.
The second item was a CPU adaptor for a computer. The item came sealed in an antistatic bag and was advertised as new. Upon opening the airtight bag the item smelled strongly of tobacco smoke, a plastic piece was broken off but it was not inside the sealed bag, and worst of all I found a small piece of dried toast or breadcrumb lodged in it.
So it appears people are getting access to some type of resealing device, though I have no idea what. I don’t know what’s available for something like this and have never seen anything like this advertised. So Great! Yet another thing to worry about when buying NOS.
What to do? As always, buy from an informed trusted seller who knows something about the product. Avoid pawnshops if you can tell that’s what they are. When you receive the tape or other item look it over carefully. The seals on all four sides of an Ampex/Quantegy tape reel should be very similar, with perhaps little fine threads of plastic from the final end to be sealed as well as a thin line from the sealer. If you see something like a quarter inch wide seal, you know that’s NOT from the factory.
Another thing to know is how Ampex/Quantegy hold-down tape for new reels has evolved over the years. Ampex was most elaborate, having a pull tap with numbers on it. Early Quantegy that was still branded Ampex had plain white hold-down strip. Shortly after that Quantgy started using either ¼” green or blue hold-down tape. The latest new reels I have use green. It’s very low tech and just serves to secure the tape. Even when I first saw that years ago I wondered about it. So, I called Quantegy and they confirmed the use of simple blue or green hold-down tape, so I know we’re good there. A pancake without a reel is almost the best bet because Quantegy continued to use a dated label on pancakes like Ampex did.
Also feel free to ask here if you have doubts. Post a good picture and many of us here can tell you if it looks right or not.
Be careful out there!
