T
t.vanbaden
Hello everybody,
I am building a new room where I am going to record vocals, acoustic guitars, brass instruments and general overdubs, mix and use as a control room.
The dimensions are: 450cm length, 270 width and 240 height.
I have calculated some of the standing waves that would occur (mathematically, not actual measuring)
125hz on the length.
209hz on the width.
235hz on the height.
244hz combined length and width.
266hz combined length and height.
314 combined width and height.
and off coarse all the summing-ups of these waves and the 3ths.
I think the best way is to start with is some broadband absorbers that go as low as 125hz with an 0.6 effective absorption-coefficient minimally in all the corners. After it I think I will measure the waves that still occur and construct tuned traps for them in places they would likely build up.
If I am thinking wrong or if you have some advice to this approach I would be very happy because I am far from an expert in the field of acoustics.
my goal is to absorb these standing waves and create a far better recording space (in an acoustic way) , I am absolutely not trying to isolate sound from the outside to the inside or the other way around!!!
Any thoughts on this subject would be welcome!
Thanks,
Teike van Baden
209hz on the width.
Thanks,
Teike van Baden
