A
ap-emerger
Well, first of all...thanks everybody for your words of wisdom and recording advice.
I wanted to post a "post-drum recording" follow up.
So, I used the Buss method to record the click & scratch tracks (onto tracks 1& 2). Then, used the Direct method to record the drums (via my Mackie mixer to get the EQ good and tasty on the drums) into tracks 3,4,5,6. They sound relatively good. No effects whatsoever. So, I am happy with the original, unadultered sound of the drums (which I'll pan, further eq & send reverb, effcts etc at a later time).
Ta'Daaa! I did it!
Now, I'll use the BUSS method to mic the guitars onto tracks 9,10,11 utilizing the XLR inputs via my tube -pre amp to color & warm the sounds. For the Guitar Parts, I'm thinking of using my 15W Fender Blues Jr with both a Shure SM 57 up close & a Shure Beta condensor for the room sound. Mix these two sounds together on my Mackie mixer & send to channels 9,10 & 11. (or however many guitar parts I want)
Then, I'll do Bass using the Direct method into track 12, via my tube Pre-amp to once again warm up the sound before I send it to the VF-16.
I guess being a long time analoge hold out, I am a bit intimidated by the "edit", "scene select" & "scene transfer" options of the VF-16. I almost want to run everything to my existing effects, tube pre's and Mackie board, while utilizing the VF-16 simply as a "recording device."
Maybe I'll figure out the manual better and get better at the learning curve & start to trust my digital skills.
We'll see.
Thanks again,
Andy
Ta'Daaa! I did it!
We'll see.
Thanks again,
Andy
