New mix/ live room design!?!
  • Thread starter Thread starter Nateazrael
N
Nateazrael
Hi guys, ive been planning to build this sucker for 2 years now and i finally have the budget!!!
So heres some of my plans etc.
My main concern is the support frame for the walls(Subdue and noise shield panels) etc..
: As you can see from the "Walls" attachment the plan is to lay "Subdue" marine ply panels onto a silent step vibration isolation layer onto the floor,
Join hardwood frames to the those from underneath and then jam the wall partitions(wrapped in some kind of rubber like "wavebar") into the channel in-between the frame.....
Finally i will wrap some panels of marine play and place them over the enclosure and apply polyeurythene sealent between all the joints and edges!
The room dimensions are approximately W2.8m x H3.7m x H2.2m
each 1.2m length of partition weighs roughly 50 kg... lets say i build the framing 600mm high, are they going to hold that wieght,,,???
The combined sound transmission loss is around 39 - 45db
Any thoughts, advice, recommendations are most welcome and appreciated!!!!
Cheers guys
Nate
