New instrumental piano cover song "let her go"
  • Thread starter Thread starter paokz
P
paokz
Member
Hey guys..Hope you like our new instrumental in a wonderful song "Let her go"
Can you tell me if you liked the mixing?
The balance between left and right hand seems a bit unsympathetic? What produced the piano sound? it sounds like the touch sensitivity is very coarse, giving the left hand a plodding feeling - sort of a loud piano sound, reduced with a fader, rather than actually played softer? Does that make sense. When the strings came in, the left hand won the battle - while the melody was a bit overshadowed? Quite liked it, but the piano sounded artificial and not quite 'right'? Same with the melody fingering. little movements with four fingers all appeared to be the same in level, when normally the third finger is always a little weaker in those runs. I've got an old Roland piano that does that. If the sampler/keyboard or whatever you used is a bit limited in sensitivity, there's probably not much you can do - so it's a nice piece that is limited by the technology, in realism terms. If the problem is in the replay of the MIDI data, rather than in the data itself, I could run it through something here and maybe make it a bit more realistic?
Love the compression on that piano. The cello or whatever is still not pretty (same as other mix) but nothing wrong with the recording. I really don't have any comments on the mix, it works very well in my ears.
The track sounds quite dark to me. The piano sounds muffled. Any way to brighten it up?
Thanks for all your comments..The cello is realistic sound samples fom 8Dio Best company for samples..The piano is little muffled cause like this its more relaxing to the ear..Should i add more organs next time?
It's up to you. My preference is to hear more shimmer from the piano and room.
Yeah it would be nice but i cannt manage this cause i tried sometimes to raise the reverb in full but nothing..t distorts the whole image of the piano :/
