New here, question about noise, static, and hollowness
  • Thread starter Thread starter voicechick
V
voicechick
Hi there!
I hope someone can help, here.
My set up (should this be necessary):
Mic: Rode NT1
Pre Amp: ART Tube MP personal processor series
plugged into my computer with CEP 2.1 . Pre amp has phantom power, which is 'on', 'Input' setting knob is almost all the way to the left, near "+26/+6", the "+20 dB Gain" button is 'on', and the "Output" knob is almost all the way left. Now, in Cool Edit, I set up a noise reduction sample of the room noise, and my voice sounds hollow and there's a static hiss in the background.
My settings for the noise reduction are:
Snapshots in profile: 6000
Noise Reduction Level: 90
FFT Size: 16384
Reduce by: 40 dB
Precision Factor: 7
Smoothing Amount: 1
Transition Width: 0 dB
Spectral Decay Rate: 65%
I can post a sample if you can let me know where it's permitted.
Thank you for your help!
-Lori
Edited to add: The sole use is for voice recordings for IVR (voice mail), narrations, and commercials. No music.
It's extremely hard to remove noise without affecting the signal you want to keep. What I do to minimize it is to use the "Keep only noise" checkbox and then Preview. I'll tinker with the Noise Redution settings until I don't hear any trace of the signal I want to keep. Then switch back to "Remove noise" and click Ok.
Reduce by 10dB might be a better plan - 40dB is pretty ambitious. If you really need to do that, you should try first to nail the noise at source.
Thanks. I'll give that a try. As for the -40dB, that was the setting, originally, so I just left it as is. I'll change that, and update.
Thanks again!
