Gizzmo0815
Ok so I've got an issue with my setup.
I've recently purchased a nice new laptop to replace my aging HP. It's a Lenovo i7 with 4 gigs of ram (I'll be putting in another 4 soon). And it runs Studio One and the Universal Control software just fine. I've got a Firestudio Mobile, which is being run through and expresscard firewire 400 port. I've also got a pair of KRK Rockit 5 monitors.
So now the problem. With my old computer I could plug in all of this equipment into the nearest outlet to my computer and it worked just fine. However with my new one, there seems to be some kind of interference which is causing an audible hum in my monitors (or headphones if I'm using those).
Here's what I've noticed. If I leave the monitor TRS cables unplugged from the Firestudio and listen on the headphones it sounds fine. As soon as I plug the monitors in (even if the monitor's power switches are off), there's a buzz. Now if I unplug my laptop power cord from the strip it's plugged into, the buzz goes away, OR if I unplug the monitor's power cord it also goes away.
Now...the next thing I tried was running an extension from a different outlet and plugging my laptop into that, which at first seems to have removed the buzzing...however! One thing I noticed about this power cord is that it doesn't have a "ground" pin on it...if I use an extension cord that DOES have a ground pin, the buzz comes back.
So essentially, if I plug my monitors, my laptop, and my Firestudio into a power strip, they're all grounded and I have the buzz in my audio chain.
If I take either my laptop OR my monitors and plug them into an ungrounded extension cord...the buzz goes away.
So the way I have it set up right now, I've got my laptop plugged into a three to two prong adapter and into the power strip. Is this 1) ungrounding my laptop and 2) dangerous?
If so, how can I fix this problem?
I've been looking at power conditioners, but I have no idea if this is the right solution for this particular problem.
Thanks for any help I can get.
