Z
zenpicker
Hello all,
I have just published a new release of Audio File Cleanup, a utility that simplifies the process of spotting and removing obsolete WAVs - those no longer referenced by your project. Audition doesn't make this easy to do, and Audition 3 doesn't improve on the situation.
With A3 out I felt it was time for an overhaul. The new version has two main improvements over the original:
- Support for Audition 3
- Ability to clean up any session, not just the currently loaded one. Rather than rely on Audition's system of locking the files it's currently using, the utility now actually extracts the list of referenced files directly from the Audition session file. So you can use it on any session, even if Audition isn't running.
The link:
Audio File Cleanup 3.0
Sorry it took so long to update this thing - since putting the first version out there in 2006 there have been over 1,000 downloads, so I know it is in wide use. My only excuse is that until Audition 3.0 arrived the old one did its job just fine, and it's just a side project for me so it never got that many cycles. I hope you'll find the new one to be an improvement - a lot of work went into it!
The link:
