promesis
Black Knights of the 4H.
Currently I run from the Direct Outs straight into the Inputs of a HD24. Now that I have gotten some Mic Pres .. I want to go direct from them into the recorder. If I add a Neutrik Patchbay and patch all 24 Recorder Inputs into the rear of the Patchbay and all Direct Outs from the Board into the rear (Half Normaled I believe ..) so that all the DOuts still Load into each track unless I plug a cable into the front of the Patchbay ("Normaling" the connection - cutting the signal between the Board and the Recorder) to route the Mic Pres directly into the recorder... will I just be adding too much signal path? Is the Neutrik "neutral" enough? Or should I patch the pre directly into the recorder? The patchbay (though a little expensive with all the added cabling) would certainly make the connections easier... since I'll be "repurposing" the Mic Pres on overdubs etc. .. but I don't want to negate the benefits of bypassing the board by adding more "poop" into the signal chain. So here are my questions?
Is this Patchbay scheme recommended?
If so, then should all of my patch cables from the Neutrik be TRS Balanced into the HD24 even though some Mic Pres and the Board's DOuts are TS Unbalanced.. or all cables should be TS .. or no matter??
-as usual .. thanks for your patience!
