blackscot
Need Some General Considerations for Recording Acoustic Guitar -- FOLLOW UP ADDED
I'm working on a collection of 70's-era "organic" rock tunes (CSNY, America, etc., stuff I grew up with) adapted for solo 6- and 12-string acoustic guitar . The material is entirely solo acoustic, and has lots of open chords and arpeggios. Recording is via ProTools/Mbox with stereo input from a pair of Audio Technica condenser mics -- large diaphram over the sound hole and small diaphram over the neck joint.
The raw tracks sound boxy/mid-rangy to me, so applying a scooped graphic EQ seems to open up the sound. I'm also using a separate high-Q parametric EQ in places to try to filter out string squeaks and other noise, but with mixed success. The only other processing is the RTAS compressor, which so far I've just been using with the factory-default settings. I've been experimenting with a couple of aspects of the processing, but thought I might ask around to possibly make the trial-and-error effort a little more efficient.
(1) Is there any general rule for what order the in-series processors should be placed, i.e. compressor before EQ, or the opposite? Switching them sometimes produces a difference I can hear, but other times sounds the same either way. Also, should the parametric EQ go before or after the graphic?
(2) I'm comfortable experimenting with the EQ settings, but am not sure how best to approach altering the compressor. Are there any general guidelines particular to using compressors on acoustic guitar recordings?
(3) Would a different mic set-up give me a better quality sound to start with?
Any other considerations that come to mind are also welcomed. The processed recordings already definitely sound better than the raw tracks, but I'd like a better idea of how good I might get them to sound, and how to do so. I realize too of course that experience is the best teacher.
Thanks for any help.
