Need schematic for Soundcraft compact 10
  • Thread starter Thread starter alan westwood
A
alan westwood
Hi,
I am in the process of repairing a Souncraft Compact 10 mixer and require a cct diagram.A service manual is £46 and as it is an inexpensive mixer and could possibly be uneconomic to repair it doesn"t warrant me buying the manual.Any help would be greatly appreciated .
Thanks,Alan.
Whats wrong with it? Generally, analog mixers like that are pretty straight forward
Re COMPACT 10
Hi,
Not if they use surface mount devices and pcb track has been damaged in the onboard power supply section the"re not!
Hi, same problem here with a SC Compact 10. In my case a burned out monitor/mix o/p section. Also need diagram.
pls ..: Help! thx WMB
COMPACT 10 Soundcraft burned out PSU regulator section
Hi, same problem here with a SC Compact 10. In my case a burned out monitor/mix o/p section) Need diagram badly!!.
correction, I mean:
In my case a burned out PSU voltage regulator section (-more or less located near the monitor/mix o/p section) Need diagram / schematics badly!!.
