need help
  • Thread starter Thread starter malvert
M
malvert
Hi,
I just got a firebox and it came with cubase LE. The problem I am having is I can get sound in, I can see that I have recorded something, I just cant hear what I have recorded. I can hear sounds in other programs, just not in Cubase. I think I have something set wrong somewhere either in the cubase software or the firebox mixer, I just have no idea where or which one. The only thing I can hear in cubase are the metronome clicks when I turn them on . Any help is much appreciated.
Devices -> Device setup, then check your ASIO drivers, select the asio driver that came with the Firebox (it probably says ASIO Firebox or something). Now find the input/output routing window, it should also be in the Device tab on the menu bar. Make sure you have the inputs and outputs set correctly there. Now set the correct output per channel on the output box in the channel (should already be correct if the input/output routing was set correctly).
