Need help with vocals (Please)
  • Thread starter Thread starter ash2004
A
ash2004
Hi there people :)
The thing is, I would like to be able to record vocals alongside a backing track and make it sound like it sit's in with the mix.
I have tried to do it, but my vocals just don't sound like they are a part of the song (They sound like a seperate thing altogether) :(
Please if anyone can help me, i'd be very grateful for your guidance.
Thankyou
PS: Would it be possible to include some easy to understand steps for me to follow? :)
For me, getting vocals to sit well in a mix is a balance of 3 elements.
1. Volume
2. EQ (which is just a different KIND of volume); and
3. Reverb
You can add "compression" to the list too, but that's just a different KIND of volume too.
As far as what you need to do, man...that's almost impossible to answer without hearing a clip. I mean, if it sounds too dry, experiment with reverbs until you kind of match what's going on with the rest of the track. If it sounds too UPFRONT, turn it down or EQ some of the mids out...Really, the possibilities are just about endless in terms of a "step by step" kind of procedure. You really just have to experiment with various types and amounts of volume (including EQ and/or compression) and reverb (or other delay effects) until it doesn't JUMP OUT of the mix.
If you could post a clip somewhere, maybe some more specific ideas would hit some of the helpful folks in here who have better ears than I do. :D
Hey Chris-
Two questions for you cool edit semi-pro:
1. With CEP/Audition, I'm also having "vocal issues" similar to this, but also with trying to monitor my vocal recordings in the mix as I'm recording. Unless my hearing is going really bad, the volume control in my vocal track doesn't seem to affect what I hear that I'm recording. It tough to keep in harmony (bad enough with my sucky voice anyway - lol) if I can't hear the vocals above the instrument tracks. How do you "turn up" your output volume (for vocals) without affecting the actual recording (to avoid clipping)?
2. Mixdown: I laid down some decent instrument tracks (2 gtrs, bass, drums) but when I mixdown (bounce) to an open track, the resulting track does not sound the same as when I play all 4 tracks pre-mixdown. It loses dB. Am I missing some key plug-in or EQ technique here, or should I be normalizing/compressing/limiting each track pre-mixdown?
BTW- I'm using headphones to monitor and a Shure SM58 mic. Thanks.
Well Ash, welcome to the board. I think every singer and every person who ever mixed a track with vocals has had the same problem, and asked themselves the same question. Do I need another mic? a different preamp? What FX can I use to get that phat sound?
It starts with the source track. There are 2 major ways in which people mix vocals. They either mix the vocal track like an instrument, so it sits, as you say, in the mix. It sounds great but no one got the words. Or- they think the singer is a storyteller, and the words are more important than the perfect sonic balance. All vocal mixes are one or the other, or some compromise between the two.
As I said, it starts with the source track. Some mics just don't work for some singers in some mixes. The problem could be mic or preamp selection, but as they say, a shoddy workman blames his tools. You have to first try to get good sound with whatever tools you have. Good mics really do help make it easier to find good sound. Listen to the room. When you clap your hands, can you hear the echo? Once you have that source track, the heart and soul of mixing is EQ. Get the best hardware or plugin you can afford, if you're going to do the mixing yourself. When you start EQ'ng the vocals, you'll see whether you want to make the singer an instrument or a story teller.
If an instrument, you'll shelve unecessary frequencies that fight with other signals (guitar, keys in particular) for sonic space. By reducing key crossover frequency bands, each signal gets its own place to live, without competing for space in the mix.. This pulls the signals apart, so you can hear each of them better. If you think its a story (everything from "American Pie" to "Stairway to Heaven") The vocal often gets a little midrange boost, and *nobody* gets to use its frequency range. For this version, you'd better have a pretty voice (Faith Hill), a very good story (Bob Dylan), both of the above (David Wilcox), or just have style (Alice Cooper).
Often the backing vox gets treatment one, and the lead singer gets treatment two. How much treatment two is in your face, or toned down, is part of the difference between Tony Orlando and Dawn, Abba, Billy Joel and Ray Charles. There is a fine thin line between cheesy pop garbage and greatness. It is the ability to use both tratments well together that results in stuff like The Beatles or the Beach Boys. First, make sure you're recording in the right place in whatever room you have, and then treat the room in whatever way that particular room needs. Good Luck-Richie
