The quest to record that 'tone'
I've never recorded metal guitars exactly, but I would suspect the principles the same. keep in mind this is just the process I use...
First I experiment with mic placement using all the mics I can (I've used up to 8...could use more but that's all the pre's I've had). I use lots because different mics blended together have given me a much fuller sound than the standard 57 or 2 on the cab have. I'll put a 57, an MD521, and
M201TG and an e609s on the grill (one per speaker on a 4/12, two per on a 2/12) then I'll put a pair of SDC's and a Pair of LDC's in distance- experimenting with distances and placement, sometimes in xy, I try until I find the sound I want. I have the guitarist play and bring differnt mics up with the fader until I find a good blend. Then I hit record
Once a take is recorded I bounce them all to one track...then i'll get record it a few more times, reseting the faders and mic placement, each set of tracks getting bounced down to a single track. once I have a few good takes of the guitar part I'll start the process all over on any other guitar parts for the song...
Once the whole song is recorded I mix it, experimenting with pan until I find how the various parts sit well in the mix. If there's only one, i'll usually leave it in the middleish...sometimes panning it slightly left or right, and the bass the same degree to the opposite sides. Two parts usually get put left and right. Three go left, right, centre (eg: two electrics left and right, acoustic in the middle)...I've panned super hard left and right and also gone just slightly off of centre.
Mixing's all about experimentation. I know there's tones of people who do it differntly than i do, and i'm sure many would laugh..but it works for me, and those I work with like the result.
Jacob
P.s...I rarely find that the amps I record are set the same as a live setting...experiment with that once you have all your mics set in relatively right placement...
