W
Wilde
Member
New here, my first post and seeking help
Let me try to make it as clear as possible. I open a DAW, there I have, for example a drum audio file. In the routing preset on the saffire mix control I select DAW 1 and 2 and hear it perfectly on the speakers. Then I plug in a guitar to my mixing console and from the console to Line In 1 and 2 on the sound card. Now, here is the problem. I can see the drum readings and the guitar readings when I strum it in the respective channels but if I want to hear the guitar through my speakers I have to select as the routing present Anlg 1 and 2 and that means that I can no longer hear the drums coming from the DAW because obviously I had to change the routing to listen to the guitar. So if a person is wanting to record as instrument in whatever DAW you are working with but you can no longer hear back up tracks, how the heck are you gonna do this? Am I missing some sort of cable from the saffire back to the console? How do I get the sounds from different sources to sound together? Because another thing is if I use the phones connection on the saffire using the DAW route on the mix control to headphones I can hear the drums but no guitar and if I plug the phones on the console and select Anlg 1 and 2 as the route I hear the guitar but no drums. It's like as if there is some lack of communication between saffire and console. At the end of the day what I am trying to say is that I can hear things from different sources but can never hear them together and this means not having any backing sound whatsoever as a guideline when I want to record an instrument.
I never had this problem with previous soundcards and this is very frustrating cuz I don't know what to do to fix this problem. All I want is to record an instrument in whichever DAW I choose listening to the backing tracks that I want from whatever source.
Sincerely hope you can help me cuz it's highly frustrating spending the days waiting for something to happen.
Thanks in advance
