and wat would be the best way to pacth that. id apretiate the help if anyone can help and also explaine how the patch bay will work with my set up and how to set it up because im new to this thanks
wilks
You don't "need" a patch bay, but doing so gives you several things:
You can extend the patch bay to a more convenient place - often mixer and outboard jacks are on the backs of the units, making repatching more work, and a patch bay allows you to have the jacks on the front of your console table, rack, or whatever.
Patch bays are also cheaper than mixers, so when you wear the jacks out from constant insert and removal of patch cords, it's cheaper to "fix" than if the jack on your console goes bad. They do go bad eventually, and a lot of devices these days use lower quality jacks than they used to back in the day.
A patch bay if wired correctly, can eliminate custom made cabling and insert cables, two things I find really irritating. While your mixer may use a TRS jack for "insert" which means you basically need a fancy "Y" cord to attach the input and the output of the outboard to the mixer, the patch bay can be wired so one jack is out, one jack is in. Makes it more intuitive and almost eliminates the accident in to in, out to out wiring that sometimes happens if you're patching insert cords in a rush.
Another advantage is you can put your patch bays next to your mixer, and your outboard and other devices "over there" out of the way, in a rack. That's what I do - most of my outboard and synth modules are midi controlled, so I have them all installed in a piece of furniture I made that's behind me. I patch things in, then I can adjust most settings by midi.
