Need help with mix down!!!
  • Thread starter Thread starter Da Arsun
D
Da Arsun
Well, I'm at the point where I'm experimenting with mixing down. Yesterday, I spent a good time in the studio mixing my beats down, adjusting the levels to where it sounded nice. When I was finished, I took the cd with my beats on it and played it on my stereo and it sounded real funny. Then I took it in my car and it sounded even more like shit!!! Please assist me with tips or any suggestions. Thanks!!!
Da Arsun said:
No... Should I try?
NO!
best thing to do is compare a favorite CD of yours, in the studio. So you know what to listen to.
Your mixes aren't translating.
You probably need to get better (flatter) monitors and/or address the accoustics of your mixdown environment.
www.bluebearsound.com <-------------- Very nice site to check out!!
People actually have told me the same thing, which is grab my favorite cd and play them through my monitors. Now, when I play my cd then do I just play my music and then compare the two and try to match my sound with my cd?
Weel, yes and no. You're going to use a CD that you're very familiar with. Something that you listen to often and on different systems. Listen to that CD through your monitors for a few hours, or days. Then, when you go to mix down your own music, you will have a better idea of what it should sound like. The idea here is that all speakers (monitors, car stereo, home stereo) sound different. You need to train your ears to recognize the particular sound of your monitors. Keep in mind though, if your monitors lack low end oomph, or high end sizzle, you will be overcompensating for it in your mix. That's why you have to be very familiar with how they sound. Something else that should be mentioned here... Don't forget that setting levels is only the first step in the process. There's effects and EQ in most mixes to make sure all the instruments and vocals can be heard. Then, if you were actually producing a commercial CD, you would sent it off to a Mastering Engineer to make some final adjustments to the whole thing before it gets released.
This is not an overnight learning process, but don't give up. Most people spend years to learn how to mix properly. Keep trying and by all means, experiment. You might just stumble across something great.
What are you using for monitors? And what's the monitoring setup like, how big a room, how close are your monitors, are they near some reflective surface's?
also take another listen to the other playback systems, your car for instance may not sound the way you think it does, take a CD and play it though you car, and REALY LISTEN to it, and pick apart the SOUND as if it were your own mix.
Thanks for the advice!!! Oh yeah and ds21 I"m using Yamaha's NS10's...
Then yes just get used to them, they aren't the most accurate speakers out there. Also I don't know your setup but you might try moving the around and see if they sound different.
Digidude824 said:
Sounds like that came straight from the Yamaha Sound Book, hehhe
er.... no... that is my own writing, thank you very much.....
How might you describe the acoustic character of your control room?
