Need help with Midi setup
  • Thread starter Thread starter AllenM
AllenM
AllenM
Member
Hi all,
Id like to setup protools as a master midi to send midi to my Yamaha Rx5 drum machine, yamaha dx7, and prophet 6 synthesizer simultaneously.
What Id like to do is compose drum midi on protools then send the midi to my drum machine to play. I would also like the same on my dx7, and prophet 6. Is this possible? Thanks:confused:
Old post, but, not super old so...Yes, this should be possible, assuming your ProTools has some kind of MIDI recorder/playback.
The cabling/connections might look something like this, assuming you have a MIDI OUT on your ProTools rig:
ProTools (MIDI OUT) -> (MIDI IN) Yamaha Rx5 (MIDI THRU) -> (MIDI IN) Yamaha dx7 (MIDI THRU) -> (MIDI IN) prophet 6
Hope this makes sense. You will need to read up a little on MIDI channel assignment. Don't worry, its like riding a bike, once you get it down, you'll never forget it ; )
Best of luck!
-PC
