Need help with Acid Music 9.0 recording difficulty
  • Thread starter Thread starter Patrick108
P
Patrick108
Member
Hi
I have started recording with Sony Acid Music 9.0 on my laptop, and the interface is Tascam 1641. What is weird about recording with it now is that after I lay some tracks (especially ones using a microphone) the playback sound gets cut off when I try to record other tracks. I will then scroll down the recorded tracks, only to find that one or more tracks has or have done something strange. What happens is that I find that the recording level (band) has stretched all the way to the end where normally if you recorded at that level it would distort. Playback from ALL the recorded tracks gets cut off (so there is NO sound). If I mute the tracks showing the recording level in the weird way, then I get the sound from the other recorded tracks back, except of course, the ones that I have muted.
So this problem is interfering with my ability to record additional tracks. It is happening on every song that I am trying to record tracks for. What is the solution? Thanks.
