T
thill
Hey,
I'm interested in turning my basment into a studio where my band can play and eventually record our material. As of right now I am not so much concerned with hardware and recording as I am with acoustics. I want to get the best sound possible in my basement while at the same time not annoying my neighbors. They live about 20 yards away and my neighborhood is quiet due to a high elderly population.
Ok, let me try to explain what I have to work with. I'm in a two story house and I want to set up in my basement. Sound travels very well through my house because of lack of carpet. Its mostly wood and tile flooring.
And on to the basement. Right now its divided up into two rooms. The room I want to use is 29ft. X 23.5ft. It has a cement floor with cement brick walls. Now running through the middle of the room are five poles. They partition off a section that I think would be ideal. I think it would be pretty easy to install a wall where the poles are making the room 29ft. X 14.5ft. Now, what materials to use and how to go about constructing the wall is what I need to know. The ceiling is made up of the foam-like tiles that you can push up on and see the stud work. There are two small vent windows on the 29ft. cement wall.
I need advice on what to do with the floor,walls and ceiling and any other tips or suggestions you think i should know.
Thanks,
Chris
Thanks,
Chris
