sheppard
just moved in to my new house and i am ready to begin converting my 20 x 24 un attached garage into my studio.
at present this structure is finished on the exterior only.(no sheet rock on walls or ceiling of interior) i have been researching for about 3 mos. now and have a faily good idea of what i want to do
but i still have some things that i need answers to.
complete sound isolation is a must, as the structure is in a residential area and my city has a noise ordanance.(250.00 fine)
let me lay out what i plan to do and ya'll feel free to pick it apart.
first i will go over the interior and caulk(100% silacon)all the places i feel air might escape.then i will insulate and hang 1/2 inch sheet rock.(on resilient channel)then tape and mud all joints and corners and caulk where the sheet rock meets the floor.
will also do same to ceiling.
after this i will use the room inside a room method.after framing in the inner walls and ceiling ,i will hang sheet rock (again on r.c.)on both,followed by a second layer(of different thickness)of sheet rock hung perpendicular to the first and adhered instead of screwed.both layers will be taped and mudded.
lastly i will install a floating floor and go over every thing that needs it with the caulk gun.
btw my entrance thru 2 sets of doors to access the live room,each door being solid wood 2 inches thick.by set i mean that each doorway will be two doors (opening in oppisite directions from one another)with a 12 inch air gap.
my nearest neighbor is abuot 25 to 30 feet away from the structure,so you guys tell me if you think this will work.
thanks
thanks
