R
RPM
Hi there; I posted this in the mp3 mixing clinic forum a couple days ago with no response. I thought I might have better luck in this section. Thanks!
I finally got a compressor (FA Soft) and used it on "God Rest Ye Merry Gentlemen" at http://www.mp3.com/RPM33 and would like to have some feedback as to whether I'm using it right. I'm preparing to re-mix around 10 songs or so with compression for an mp3.com CD, so I want to make sure that I get it right. Basically, I used a ratio of 5.6:1 and a threshold of -23dB on the vocals and a ratio of 1.9:1 and a threshold -19dB of on the whole mix. Is this too much, or too little, or just right? I'd hate to overdo it and have an undynamic mix. Any other compression tips would be welcomed.
Also, my ears tend to hurt a bit after listening to it...could that be due to the EBow being really mid-rangey? I heard once that the mid-range, rather than the highs or lows, is the main contributor to hearing pain. If this is the problem, how much should I scoop the mids to make it less painful. Any input would be appreciated. Thanks! Rick
