C
Consul Records
I Have a M-audio Sputnik microphone, but the problem is, that i don't have a power supply for it, which is a big problem because it is a 7-pin multi-pattern large diaphragm vacuum tube condense microphone, and there is no way to get it I live in Czech republic and here it's impossible to order it. But i have a friend which has a NADY TCM 1050 power supply, which happens to also be 7-pin, with a xlr-3-pin output. So i checked the specs to make sure everything is fine and the only noticeable difference would be the sensitivity which is on the NADY TCM 1050 power supply is 15 mV and on the Sputnik is 30mV.
So if anyone knows if it would be usable and if I can connect it please let me know.
thanks
thanks
