My uneducated review of the MXL990 from another thread
  • Thread starter Thread starter Freudian Slip
Freudian Slip
Freudian Slip
Just in case anyone is wondering about the 990 I did a little testing on mine today. This is a follow up on the Should I buy a MXL 990 thread, but I thought I would let people know I got one and what I think of it. The mic was run threw the pre only on a Mackie SR24-4 VLZ board. I used the same xlr cord as I always use with my AT-3035. All EQ mentiond was on playback.
Well I'm back after more testing on vocals. This time I spent a little more time on it. Keep in mind that when I compare to my AT-3035 that it (the 3035) has the pad and the roll off both on.
I would say that having the roll off on is fair because the 990 specs show to be close to the 3035 with the roll off on (on the bottom end). The main difference I see is that the 990 has slightly less presence than the at 3035 and that the signal varys more greatly between being at 6-8 inches and 12-14 inches on the 990 than on the 3035. This could be a disadvantage for those singers that can't stand still. The sound on vocals is very useable. With me it woud require some EQ but nothing to drastic.
Edit: the fact that the MXL 990 has a boxier sound and some what less presence than the 3035 it against the printed spec sheets. the 990 shows a wide high boost of at least +5db centered at around 9khz spanning from 4khz to 19khz while the 3035 is pretty flat. Both mics show flat from 2khz almost down to 100hz. One of these mics is quite a bit off the printed specs. I will try to find out which one. Any one know a place I can download a wave file of white noise?
I could not hear any large proxemity effect on the 990 on the low end. I also tried it at 45 deg at 6-8 inches and 12-14 inches and got pretty much the same results.
This mic seems to be a little boxy sounding. Later in this post I sort of settle on the notion that it lies in the low mids.
I belted into the 990 at 6-8 inches and could detect no distortion even though my software waveform was showing I was reaching clip. I am using cakewalk though and I have never had a great deal of trust in the wave form image as far as clipping goes.
Next I tried it on drums (keep in mind my room sort of sucks).
I thought it sounded pretty accurate. once again to me it seemed like it lacked presence slighty most noticable was on the snare but then I have mic'd this snare close with a sm-57 and it I often add a little air to the mix. I think it did a pretty good job over all and am thinking of ordering another one to use as with this one as stereo overheads. It is a cardoid pattern and that helps me because of my room. I think I would rather have super cardoid but with a little more work on the room and some shielding for the kick These could really work I think.
Next I tried it on accoustic guit. And this time I tried a little EQ after I was done. I thought it did pretty good but still a little boxy. I tried addin some highs and didn't really get what I was looking for so I tried scooping a little around 400hz and walla. It deffently made a greater improvement scooping 400hz by 2 to 3db than adding the high shelving from 12khz up.
So I think the highs are there but being masked a bit by low mids.
a 2 to 3bd adjustment is not all that bad and I can deal with it no problem.
For $70.00 I am going to give it my thumbs up:D
I have no Idea if a B1 is better or worse but I think you will be getting at the very least your moneys worth with the MXL 990.
EDIT: I also wanted to add just in case I seemed critical of this mic that given th choice between using the 990 or an sm-57 for recording vocals in most cases I would reach for the 990. the detail it captures out wieghs any minor eq work you would have to do. I was however hoping it was a $200.00 mic in $70.00 clothing due to introductery pricing, I think it is maybe a $100.00 to $125.00 mic in $70.00 clothing.
Later
Dave
Your Educated Review
Mr. Slip your review of the MXL990 seems very educated to me! you did a outstanding job of informing others the working of this mic. I agree with you whole heartly about this mic, when I added some processing to it the boxy sound rounded out. I belive that for someones first large condencer mic they can not go wrong.
I will have to say it is a keeper for me too, and that a second one for over heads or stero recording will workout just fine as a addition to my mic locker or anyone else's as well. Good job!!!!!
Gary
spanks, lites out. I am glad to know that your mic sounds about the same. I wouldn't want to order another and end up with a huge difference in tone:D
F.S.
Well Spanks u-ttoo!
I thought I was the only one who said that? but hey theses are not bad mics? that can be very useful. at the price of $70.00 Marshall is giving them away and with a CAD pop screen too! you can not go wrong on this one . I am going to put my order in for another today, even if they are on back order I can wait!!!!
Freudian Slip,
You can generate white noise with your track editor (like Cool Edit Pro).
How would MXL 990 do on a bright tenor voice ? My Studio Projects C1 needs heavy reduction in highs (see my post in C1’highs topic).
fireworks123 said:
Freudian Slip,
WEll?? It's hard to say for sure. The 990 is not as bright as my 3035 and my 3035 is not overly bright on my voice. I can get a vocal track out of the 3035 that is very usable with out any EQ.
I could not really tell you how it would do for sure because I haven't tried. My guess is that it would do pretty good though.
When I tried it my first impression is that it would be better for a tenor than for me. I think the key would be having a voice without a lot of low mids (I am mister low mid). then I think it would shine much more.
Hey it's $70.00, give it a try. You can always send it back to MF:D
Later
F.S.
fireworks123:
Of course if wou hate that C1 we could always trade:D
I have always wanted to try one. It was between the C1 and the AT-3035 when I got my 3035. I think I got the 3035 for the same reason I would never own a camaro. Everybody has one. Some day I will get a C1 and see if I f@cked up bad:D
Later
F.S.
This isn't by any means a review of the MXL 990, but my son Alex wound up using it last night on a jazz/rock group to record saxaphone and acoustic guitar. He was very impressed with the sound of it.
Alex will be here all week, so we hope to be able to test the following units in depth:
TLM103 (Our standard for these mic comparisons)
All the Studio Project mics.
The MXL 990, V69, and 1006
AKG C3000B
The VTB-1 preamp
The RNP preamp
The Speck 5.0 preamp
The preamps will be compared to each other and to the Millinia Media SST-1 and the Great River MP-2NV.
Please be patient, since this means testing 10 different mics against each other (about 90 different tests), trying to figure out which would be useful on what instruments, trying to explain the different sonic characteristics of each mic (good and bad), and averaging opinions from two different people, listening in two different evironments (me in the studio, listening over headphones, and Alex in the control room, listening over the main speakers).
It's not an easy job, especially when you consider that our primary purpose for being in the studio is to record the bands that are coming in every day for the next 3 weeks. We try to do our tests before the bands show up, so that means the tests will be spread across many days.
Finally, I want to be very clear that these tests are just our opinion of how useful these mics might be - it shouldn't be considered as some sort of absolute verdict of a mics usefullness. Unless the mic has serious sonic problems (screechy or peaky top end), we'll usually be able to find some use for it. If the "useful list" is very short, we'll point out other mics in that category that might be more useful.
And it is, after all, charity work on your part. Much love, much respect and inadequate thanks.
-kent
Cool Harvey!! I'll be interested to see what you and your son think as to the 990 vs the b1. Not that it will necessarily be that one is all around better than the other, but more that I would like to know if there are any obvious frequency response differences ect. I could see this working well for brass, makes sence.
Have a good one.
Later
Dave
BOXY...
Hey Freudian Slip,
Have you found a way to get rid of the boxy sound on the vocals? I noticed it the second I used it. I also tried to drop a bit of the low mids, but I was still stuck with a really boxy sound...not sure what to do!
