H
Hallatar
My soundcard problems seems to be endless. When I fix something, new problem shows up
And the problem. When I'm recording electric guitar with Sound Forge 5 result is clear and good (as you could expect from Audiophile). Now I need a right beat. I open Logic and play the midi file and record: sound is distorded,clipping and sounds awful. Same happens when recording just with Logic without Sound Forge. I've locked the samplerate so that shouldn't be the issue. I've tried 16bit 44.1Khz -> 24bit 88.2Khz and all these rates have same problems. I've messed with all buffer settings and my options are: horrible and totally useless. I think my problem is software issue and all I need is the right setups and configuration. My hardware should be fine.
Here's what I'm using:
1000 AMD Athlon
512 Mt ram
30gt HD (7200 RPM)
Audiophile 2496
Audio Buddy
V-amp2
Logic Audio 5.1
Sound Forge 5
Gigastudio 96
(Drivers are updated and I've optimiced my pc.)
One solution might be a second hardrive. Gigastudio, wich is software sampler, uses a lot system recources. Maybe it is too much to stream giga files and high quality recordings at same time. Althought I can't record even one single clean track with Logic (no other apps on).
So help me out again!!! I'm starting to get really frustrated. I've had problems for a almost half year now
1000 AMD Athlon
512 Mt ram
30gt HD (7200 RPM)
Audiophile 2496
Audio Buddy
V-amp2
Logic Audio 5.1
Sound Forge 5
Gigastudio 96
