my notes are repeating
  • Thread starter Thread starter rguagenti
R
rguagenti
Something weird is going on.
When I input notes on the music staff view in Homestudio2004XL they repeat elsewhere in the track. If I try to delete the duplicate, it deletes the original as well. Somehow any notes I add are linked to somewhere else in the tracks, therefore, whatever changes I make in one measure are repeating in another measure within the track.
Am I going nuts or what?
Is there a way to unlink this mess.
Thanks.
Sounds like when you are copying you are pasting as 'Linking Clips', what happens here is that when you delete a note it one, it deletes all the other instances unless you paste the clips as non-linked. The option is a check box on the paste screen.
Porter
Makes sense - is there any way to unlink copied clips without deleting and re-pasting?
Q.
I haven't used clip linking since PA9, but then you could just right-click on a clip and select "Unlink".
Moskus, Thanks.
Is that the reason when I add a note. it appears double on the staff. In other words I would add a C note on the staff, and another C note will appear as well, kind of attached to the hip.
