miroslav
Cosmic Cowboy
I picked up this little baby over the weekend, it's an Otari MX-80, 2" 24-track and the CB-124 remote.
It was only about an hour and half ride to NJ to get it. A bit of work loading it into my pickup, and then again unloading it was even a bit more of a challenge and getting into my studio...but my buddy and I managed it pretty good for an almost 300 lb deck.
The great thing is that the seller had JRF do a head re-lap and there is 75% life on both the Rec and Rep heads, and the Erase is listed as 100%. He also had the PSU's overhauled for both the deck and the controller. He only used it a couple of times after getting it done, so I won't need to worry about the heads any time soon.
The seller included a HUGE pile of extras...
Timeline MicroLynx sync unit with two remotes (will need to fabricate a cable to the deck, but not a big deal).
2-speed MRL tape, almost new.
28 used tapes - 16 Ampex 499, 10 Ampex 456, 1 3M 996, 1 EMTEC 911 - some will be SSS crap, I'm sure, but there should be at least a dozen or more good ones out of the bunch, so that will hold me awhile.
A couple of boxes full of spare parts (some new) - 4 channel cards, and various PCBs covering almost all that the MX-80 uses, including two spare transformers (they are massive, the size of small melons), and a bunch of harnesses, ribbon cables, a couple of VUs, and some extra panels and hardware...etc...even an Otari cooling fan unit (long, tubular fan)...though the MX-80 is a fan-less deck, but I think this is like an optional item. I'll have to see where it would go inside (maybe it's not for the MX-80).
A box of cabling, though some of it is for other recorders, like for the MTR 10/12 units, for hooking up NR systems (I'll probably unload them), but also cables for hooking up Dolby for the MX-80 (if I ever get any).
Extender card for calibration/service.
Complete factory MX-80 manual in hard cover binder covering operation, maintenance, alignment, parts list and schematics. It's like new...as though no one ever turned the pages...not a wrinkle, tear or mark.
He even included a brand new Handy Mag demagnetizer and a large bottle of 99.953% isopropyl alcohol.
All in all, it was a LOT of stuff...and it will take me awhile to sort it all out, but I'm glad I have all the spare parts. It will save me a lot of time hunting for replacements if anything ever goes bad.
The whole pile cost me $2200...not a bad deal.
I had the deck up and running today, tried out a few reels of tape...AFA as basics, everything seems to be working OK, but it will take me awhile to get the deck completely installed and hooked up for actual recording. Plus, I need to spend an entire weekend with it just going over everything and doing all the functionality checks. It's probably been sitting awhile, since the seller said he had hardly used it at all since he got it set up, so I'll let it sit idling for a day or two, and just run some tape on it just to "loosen" things up a bit...and hopefully there won't be anything bad popping up.
