my new recording technique (guitars) using a Weber Mass Lite
  • Thread starter Thread starter GONZO-X
GONZO-X
GONZO-X
The new recording technique (guitars) using a Weber Mass Lite and Palmer PDI-09
well, my new toy for xmas, is a Weber Mass Lite, 100w.
https://taweber.powweb.com/weber/masslite.htm
it works pretty well..
here's how i use it:
i go Mesa boogie Mark IIb /speaker out (8 or 4 ohm, it doesn't matter) into the Palmer PDI-09.
speaker out into 'INPUT', and then back out via the 'THRU', and that goes to the Weber, for attenuation.
From the Weber, speaker out to whatever cab i want to use (the demeter if i want to play loud, the celestion greenback cab if i want to monitor 'open air'.
the 'BAL. OUT' on the palmer, is an XLR out, that goes to my mic preamp, convertor, and into my recorder.
the switches on the top of the palmer give me line level attenuation, and 3 different 'cab and mic' sounds.
i like the NORMAL setting the best. It's all passive, the weber and the palmer, so i'm not introducing any kind of electrical noise at either of these two units.
the weber:
the feel of the response to the speaker, feels more natural to me than other attenuators i've used before.
but, i've got to run it almost maxed out to get the 'bedroom volume' control i want for actually using my speaker cab for monitoring.
luckily, i have a Demeter iso box, that i can use as a load box to run the weber a little hotter (less attenuation, i mean)
the little palmer pdi-09 unit is the thing that's stealing the true 'amp wide open' sound, so the weber is strictly for monitoring purposes..... i'm not micing the cab.
notice the (2) attenuators.....
the mids/highs one on the right, just works a little bit...
most of the energy is going to the lows and mids, so the attenuator on the left i've got maxed out, and then backed off a bit (about 1) with the highs set at about 2 or 3.
when it's maxed out, i can actually hear the speaker motor inside the cage working.
oh my god, don't dare hit the bypass switch, when the amp has the master sitting on '7'.....
LOL
i did that, just to hear the sound of the amp sitting on idle.
just that, was louder than conversation volume.
the boogie really sounds different, with the master almost wide open.
the entire tone stack, opens up, and the mids become very throaty.
6L6's like to be pushed hard, that's when they become 'musical'.
when you're using a tube amp with the master on '1', and the preamps dimed, all the tone is just preamp distortion with eq, and everything else, is just sitting on idle, and preamp distortion, isn't nearly as sweet as the power tubes cooking themselves to death.
the unit does get a bit hot...
and smells funny, at first, but the more i use it, the new burn smell is starting to go away.
i do not miss the tone stack of the full Mass at all.......
the low and hi control, is enough.
maybe, if i was micing the cab, i might want a bit more control, but honestly, if i want more bass or less treble, i'll just tweak the amp.
using this device, has cause me to re-think all of my gain structures, and choices of eq settings.
the pedals, seem to have more tone and control, now that i'm running the boogie at it's optimum setting for 'output distortion'.
the first one i got (yes, this is my 2nd one) was dead in the low-mid side....
it was just passing signal, and not attenuating anything.
weber was cool about it.... sent me a paid for shipping tag, and built me a brand new one, and shipped it for free.
that was the least they could do, after sending me a unit that they obviously had not demo'd before sending it.
but this one works fine.
i'm not curious enough to open it up yet...
but eventually, i will.
i just finished my first full song using this setup.
i chose the 'BRIGHT' palmer setting, just to get a super crunchy in your face tone, and used a 'V' cut on my graphic on the boogie, to approximate a more modern amp tone....
i'll post that one soon.
to hear just the palmer (without the Weber) go here:
https://homerecording.com/bbs/showthread.php?t=255635
nice-- looks like i'll be adding the pdi-09 to the list :)
it really works well, using a send from the palmer, AND micing a cab, and blending the two, together.
but the reason i went with this setup, is because i can't mic a cranked amp...
and i like how my boogie sounds and reacts, cranked.
so, this is the compromise setup..
and works really well.
the palmer, also, is a gem, for live setup.
i'll never mic my live cab with a 57 again.
Never really gotten to play with a Palmer, but I always thought Satriani's tone took a dive for the worse after he started cutting everything direct...
Anyway, I'm a THD Hot Plate user myself (those and the Webers are generally held to be the best on the market, from what I've heard), and the difference between my Rectoverb without on with the volume at 1 and wiith one @ -12dB with the master in the 4-5 range is absolutely huge. You could never own an amp like this as a bedroom rig without some sort of an attenuator. I swear by mine, and recommend to everyone who owns a tube amp and isn't, say, on tour opening for the Stones.
Can't listen to the clips from work, but I'll do so when I get home. :)
i'm pretty sure that he's recorded that way ever since surfing with the alien.
yep, i agree with you, having the attenuator, gives a high watt amp, a chance at getting to be used at home.
LOL
without the divorce or eviction.
i've demo'd quite a few low watt amps (even bought a peavey JSX mini colossal!), but they just do not put out the tone or grind that a 20 watt plus amp puts out.......
and tho i love the sound of a really fine cranked cab, in a good room, this situation is always few and far between....
and i'm finding with blind listening tests among folks who don't know what i've used, they're completely unaware of the difference.
what matters most for me, is the way it feels, when i play.
i've tried the modeling route, and nothing i ever did with the modeler, feels like the real thing.
When you do open it up send me a picture of the guts. I've been wanting to build one of those to use with my Carvin Legacy.
Nah, I'm a bit of a (recovering) satriani fanboi, I can probably list off a pretty comprehensive list of what he used when off memory. :lol: "Surfing..." had a lot of a Rockman pre on it, and I think some of it might have been cut direct (though, to be fair, it's hardly what I consider a landmark album of good tone), but by "Flying in a Blue Dream" onwards he was using mic'd rigs.
It was only on Engines of Creation when he began using the Palmer in a studio setting. It actually worked quite well given the electronica viibe of that album (which I seriously like, particularly "Clouds Race Across the Sky" onwards). Strange Beautiful Music, though, sounded like a demo - basically, it was, as it was mostly Satch's home studio scratch tracks that made the final recording. "Is There Love in Space" had him using a Peavey 4x12 a lot more, but by Super Collossal he was back to using the Palmer almost exclusively. Only a few tracks - the leads on "A Cool New Way" and "Crowd Chant" were cut with a mic. Ironically, that first lead was about the only thing on the album I thought he'd gotten a good tone for, and it was only after reading an interview a few weeks later I was able to confirm it wasn't a Palmer and that's why the guitar sounded so much more liquid.
I've been pretty underwelmed with Satch's last few albums anyway ("Is There Love in Space?" was decent, but SBM and SC were pretty forgettable across the board), so the fact the guitar tones haven't been so hot hasn't been a huge deal for me. But, if you go back to "The Extremist" (Mark-IV, I'd bet, though I've never heard for sure what his rig was on that album... Sounds like one to me though) and "Crystal Planet" (easily my favorite "shred" album, loads of different Marshall-y heads on this one), and then contrast the tones he was getting there to SBM, it's like night and day...
He's got a new one coming out. I'll buy it regardless - the dude's a hero of mine and completely opened my eyes to what you could do with an electric guitar - but I can't say I'm getting myself get too worked up.
Didn't listen last night, by the way - I practiced for an hour or so, then my roommate and I ended up getting loaded on gin and tonics and playing guitar hero, lol.
ocnor
gut shots, got it!
i know very little about it, but from other conversations i've read, it's a series of resistors, married to a working speaker motor (magnet, voice coil, just no paper cone)
drewpeterson-
yeah, engines of creation had a very modern, in your face sound to it, didn't it....
that was a cool album...
some of his last 5 albums, were really good... and the rest, yeah, kind of forgetful... or at least, sounded 'familiar' to something he did earlier...
my favorite guitar sound of his, was off that extremist album. know what you're talking about there....
Oh god yes... I'm a late Satriani convert, I only really got into him after "Crystal Planet" came out, so for me I bought that disc after having a pretty good idea what to expect of him. I remember I came home, popped that disc in, hit play, and thought, "Holy SH!T that's a heavy drum tone!" before the first chord kicked in. I was expecting something more Metallica is, from that first slide and the sound of the drums, and then suddenly you get this happy uplifting tune...
Tonally I agree though, it's probably my favorite sounding Satch album. If my disc comes out sounding half as good as that does (if I can ever finish writing, lol), I'll be ecstatic.
Some day you will have an opportunity to use your tube amp full wide open, to cook those power tubes without getting divorced, evicted, or arrested......
At which point you will have the notion to remind yourself what the amp used to sound like without any attenuator stuff in line.....
Trust me, you will be VERY surprised at what you hear....... :)
NAH.....
after 6 years of full time road work, i kinda got that part down!
and the tinnitus to prove it!
