Okay! I think I figured out problem number uno.
I decided to not be such a jackass and suddenly remembered that I have two mics...........so I tried the other one......and...............it works.
So I'm assuming the other mic is a dud or is broken.
Blue Bear Sound said:
Without the BlueTube plugged in to your mixer, are the meters reading anything on the BlueTube when you make a noise thru the mic? (This would mean your mic and preamp are capturing a signal and working...)
Yes. The BlueTube's led meters are flashing now. So I'm getting sound from the mic, HOWEVER....it is very distorted and especially with high sounds, it makes me sound like a robot and there is A LOT of popping and hissing.
Then.... the output of the preamp would go to a HI-Z input on the mixer, because the output of the preamp is now at line level, so you don't want to send it to the preamp in the mixer.............
On each channel on my mixer there is a low z input for xlr and a high z input for 1/4". Both the male and female ends for both of my mic cords are xlr. Are you saying I need to get an xlr->1/4" for mic->preamp and then use a 1/4" jack for preamp->powered mixer? If so, that would mean I would be using the unbalanced output (1/4") from the BlueTube. Is this okay?
Can you do this? :
mic----> :xlr:-------------:xlr
reamp:1/4:---------------:1/4:Mixer
If so, then I wouldn't need to get a new cord and that would be sweet.
So why do I need to go into the hi z instead of the low z on my powered mixer?
