Bulls Hit said:
Bad idea running your disk traffic accross the pci bus. Virtually guaranteed to interfere with your audio card. It would be better to get rid of one of the DVD drives. Otherwise if you can't squeeze 3 drives in there, you're better off just sticking with 2
There are ways of minimizing this.
1. Free IRQs by turning off unused devices. In theory, the interrupt controller on your motherboard should be able to salvage those newly-freed IRQs for use by PCI slots.
2. Find out how your PCI slots are ganged. In a three slot system, often one would slot be on one IRQ and the other two on a separate one. One may share an IRQ with the video hardware in some cases. Adjust card placement until the drive controller and the audio card do not share an IRQ.
3. If you have bandwidth constraints, you'll also be happy to note that due to trace length restrictions, the maximum number of newer, higher-speed PCI slots per bus is often as little as 1 or 2, so on any system with more than 2 slots, odds are you have more than one bus. The advice above about sharing IRQs... also applies to sharing busses.
4. In rare cases, you may still run into problems that can't be solved by the above. In those cases, you might try reducing the maximum DMA mode for the drive through software. This will force the drive performance to decrease, resulting in greater available bandwidth for use by other devices. That said, this is gross and should be avoided if at all possible. (There might be other rate-limiting mechanisms, depending on OS. I'm not a Windows person, so I couldn't begin to guess.)
