Greetings,
If I were to produce a "quadraphonic" recording (stereo 4.0) is there any format I could put that on? I've heard a little about DVD-A, but having never created one or listened to one I'm not sure how to proceed. I already know I'd only be able to play it back in a DVD player connected to a surround system... but would a quad mix translate into something one could do on a DVD-A?
Thanks,
Owen
Welcome to the nightma...er...board, Owen!
There is an alternative that does not require DVD, Fraunhoffer (the lab that devised the first and best MP3 algorithm) has made available the
MP3Surround format, that will go up to 5.1 surround. There are (as usual) pluses and minuses here.
On the plus side:
- it does not require DVD for distribution; it is an encoded computer file format just like MP3 and can be distributed/played back on any machine that will support MP3 playback.
- it is also reverse-compatible with standard stereo MP3 players. That is, if you have just a regular stereo MP3 player like an iPod or Winamp or a standard CD-R or DVD-r player, your quad files will play just fine, they will simply decode in stereo.
- while it is a newer format (2004), it is becoming more accepted every month. they have added Playstation to their list of MP3Surround support, and there is a free player available for it.
On the negative side:
- it's a different format than what's used for most other surround purposes such ad surround video and DVD-A. It would for the present require (AFIK) rendering/exporting separate versions for those formats if you wanted compatability across the board. Whether that will still be true 18 months from now or not is only a guess, though.
- as it's a newer format, there's not a lot of current players that will playback the surround file in surround, but rather in stereo only. I suspect that will change pretty rapidly in the near future, but for today, the number of legacy/popular MP3 players that will play an MP3Surround file in actual surround rather than in stereo is small.
- I'm not sure of how many current editors have the MP3Surround encoder available to them. There is a separate encoder available, but whether it's an option in a lot of current editors, and which ones, I'm not sure. maybe others can chime in here on that for us.
G.
