pchorman
Can anyone explain why an amplifier should have more than one means of rectification? I've gone through Mesa's on-line documentation and come up dry, so I'm having a hard time buying into this. That's not to say their sound isn't awesome; it's just the recto packaging/marketing ploy that bothers me. I'd like to know whether this feature is even used by anyone and how much of a difference it makes.
To me a rectifier is just a means of converting AC into DC to power the amp. There are good rectifiers and there are bad - that's it. A "good" rectifier produces clean, well-regulated DC voltage for consistent power distribution throughout the amp at any volume. A "bad" rectifier has an inadequate filter (producing ripple which contributes to audible hum) and exhibits lousy voltage regulation which means inconsistent behavior at different volumes. Why do I feel that the vacuum tub recto is meant to do the latter, and what is it's appeal? If dynamic response is the factor, there are better ways to achieve it then with a poor rectifier.
By the way, every amp that plugs into a wall outlet needs and contains a rectifier. Why then is there a "Single Rectifier" model, as if this is some unique feature? All amps meet that description. If I'm off base here then set me straight. I post this question here rather than with Mesa because I'm hoping for an unbiased response.
Thanks
Thanks
