M
miekedmr
Hi, I'm looking for something to allow me to do multitrack recording onto a PC into an application like cooledit pro. I believe the M-audio 1010 is roughly what I want, but it seems a little outdated based on the manual, and the capability software-wise is a little unclear. I need something that will allow me to record all the inputs seperately at the same time while also mixing them and passing them out a single output for monitoring. Six inputs is the minimum. I also need good ASIO support. 96Khz 24-bit is plenty considering the mediocry quality of sources and that everythings going to end up 44khz 16bit anyways.
I use the 1010LT and it works great. The 1010 will do everything you say you want from a soundcard and it will work fine with CEP.
