D
djclueveli
i'm reading the bob katz mastering pdf file on MS mode and it says "A simple audio decoder (just an audio mixer) combines these two channels to produce L (left) and R (right) outputs. Here’s the decoder formula: M plus S equals L. M minus S equals R. Here’s how to decode in the mixer: Feed M to fader, Feed S to fader 2, pan both to the left. Feed M to fader 3, S to fader 4, invert the polarity of fader 4 (“minus S”), pan both to the right. The more M in the mix, the more monophonic (centered) the material, the more S, the more wide-spread, or diffuse the material. If you mute the M channel, you will hear out of phase sound, containing largely reverberation and the instruments at the extreme sides. Mute the S channel, and you will largely hear the vocalist; the sound collapse, missing richness and space.” How would i accomplish this with Waves SI plugin because it has MS mode on it and i am mixing with Acid Pro. Can anyone give me Step by Step directions on how to do what Bob Katz is talking about, with Waves SI plugin. thanks
