mp.3 encoding
  • Thread starter Thread starter Treeline
Treeline
Treeline
I'm getting a "conversion terminated" message when encoding an mp.3 version. I previously had a "succesful rendering" message, so I'm puzzled. It doesn't create an mp.3.
Treeline-
The one thing I think N-Track sucks at is MP3 encoding....my free version of Musicmatch does a better job.
Just my input, hope it helps.
H2H
Ahhhh... I installed a program and didn't reboot before running n-Track. When I rebooted, I found the mp3.
Handy tip: Never wire your furnace to a dimmer switch.
Agreed. n-Track uses Blade which is one of the worst encoders around...or at least it was last time I used it.
You might also look into SCMPX which does a much better job than blade, especially down at 128kbps.
As for your actual problem, if it's still a concern, you might take it directly to Flavio if nobody here has had this problem. (I don't think many n-Track users use the built in MP3 encoder)
Slackmaster 2000
Thanks, Slack. I expect at this stage of my learning curve (as in "vertical") the real problem isn't with the program...:rolleyes:
Whoa, you musta got your reply in there just seconds before mine. I didn't see it :)
Slackmaster 2000
