C
ChrisU
Hello!
I'm considering acquiring this device as an end-all for me ever needing more inputs and outputs, sometime in the future, but definitely not right away. Its webpage says that it can be used as a core system that comes with a PCI-424 card. So, I just want to make sure I have it figured out before I get set on buying it; if anyone can answer any of these questions I'd really appreciate it!
1. I'm planning on building a dedicated music desktop with an ASRock Z77 Extreme4 motherboard, so would the MOTU PCI-424 go into a PCI slot or a PCIe slot?
2. I'm aware that it doesn't have any preamps or phantom power inside, so I want to make sure my imagined configuration would work: for example, an AT2020 with an XLR cable into a Nady TMP-1, then from the out on the preamp run a TRS cable into the first input on the MOTU 24I/O?
3. Is it compatible with PreSonus's Studio One?
4. I'm also at a loss on how to hook up monitors to it, since it has no volume controls whatsoever. My TASCAM US-1800 also has some line outs with no volume controls and when I connected headphones to them they just blast super loud, but I believe the volume can be controlled in the DAW. With monitors (like PreSonus's Eris E8's), would I need something like Presonus's Monitor Station? I.e. run a TRS cable from output 1 on the 24I/O into ST1 Left on the Monitor Station, then out from A Left on the Monitor Station into the monitor? But how does the MOTU designate left and right? Do you establish that in the DAW?
If you've read this far then I applaud you. Sorry for such a long post, but it's a good chunk of money to spend only to find out I had no idea what I was doing. If anything I've said in the questions was dumb, feel free to yell at my noobness.
Thanks!
Chris
Thanks!
Chris
