G
geetarzan69
I've been running my studio with the old MOTU 2408 Audio, so I bought the ADA8000 to add more tracks. I have it hooked into bank B of the MOTU through ADAT in. On the ADA8000 I have the switch on the back to 44.1 khz, but I dont think that's right beacuse isn't is supposed to be a slave to the MOTU rather then Master/Locked? Anyways, I have the clock source set to internal on the MOTU as it's always been set, and I set bank B as ADAT in the MOTU PCI control panel. I'm using Nuendo to record, and all the mics/inputs I'm using through the Behringer have pops/clicks in the recorded track. I've tried setting the clock source to ADAT, and Bank B Optical and none of that works, the 44.1 and 48 khz lights just blink on the MOTU. The only way it actually records is if I have it set as mentioned above and I'm getting digital clipping and popping and I don't know if I need to change any settings or if anyone else had any problems like this? Any help would be very greatly appreciated! Thanks so much!
-Trevor
-Trevor
