M
Merle
First, thanks for all the good info I read here!
Since my last posts, I have purchased SONAR software and learned most of the basics of mixing.
Now, a question about .wav files. If I import a .wav file onto track 1, how or can I import another .wav file and append it at the end of the the first .wav file on track 1? I need to do this 4 times so that I have 4 .wav files imported onto track 1, so that when I play the track 1, the 4 .wav files will be played one after the other until all 4 .wav files have been played?
I need to do this so that I can mix all 4 songs the exact same way, since all 4 songs are related to each other (a flamenco sevillanas thing) and must be played one after the other, and since I did not record them all in one setting, but 4 different recording sessions (hence 4 .wav files)!
Another question. I have recorded and mixed 14 different .wav files and soon I want to put them to a CD. How do I make sure that all 14 songs have the same "volume" before I record to CD so that the listener will not have to be adjusting the volume on their CD player?
I tried to make sure that I used the same volume settings in SONAR for all the songs, but I want to be sure that I am doing this right.
Your pro advice would really help...
Merle
Merle
