More Qs on SONAR and M-Audio omnistudio
  • Thread starter Thread starter amt7565
A
amt7565
Guys,
I am using SONAR with Delta66/omnistudio. I am trying to route out individual tracks through the omnistudio "direct outs". It has 4 outs and I would like to route 1 stereo guitar track out of "direct outs 1/2" and two base (mono) tracks through "directouts 3/4".
I have played with it and SONAR but I still can't hear 4 independent tracks through the "direct outs". I can only hear 1 or 2 tracks at a time. ALso the IN switch has to do something with it.
Anyone has a procedure that can help me? How do I route this from SONAR and then the Delta66 patch panel and then the omni studio device itself thorough the "direct outs" ?
The only thing I can relate it to is my Dakota. Any cake out (V-main) can be asigned to any of the (in this case 16) outputs. They all appear in the dropdown list in Sonar's tracks/outs. Is 'direct' out just normal outs?
What about in the 'options' (or 'tools', don't have it in fron of me)?
Think they should also be in there also.
Wayne
this problem is simple
setup a track with delta 1/2 as out wit no panning for the sterea guitar then set up 2 tracks with delta 3/4 as out pann one hard left and the other hard right and u should have 3 different outputs coming from ur card
Open Sonar options/audio/drivers and make sure all the delta ins and outs you want are highlighted (selected). On restarting Sonar these will all show as choices in the track out drop down menu.
To ensure the delta card is actually outputting say 1/2 on the outputs 1/2 ,open the delta control panel and check in the patchbay/router that the physical (H/W) outputs are being fed from the correct output driver. It's possible that you may have the monitor mixer feeding an output for instance.
