Michael Jones said:
Yes. All the seams still need to be caulked.
I'll do 'em all at once when I finish the stops.
It's 5/8" fire rated sheet rock. Its supposed to provide a one hour fire break.
Yep, and it will provide that in a lab.
Assuming you have a
serious fire, and not a cigarette butt tossed in there smoldering...
Because the rooms aren't tied together, you have a lot of air between the walls and that air will be sucked down across the floor towards the fire (through convection), thus providing a constant source of oxygen.
The flames of course will go up, and probably burn the structure between the two rooms, unless you sheet rocked those as well. Doesn't look like it from the pictures, but maybe I'm making an assumption here.
Anyway, if you screw/glue up the fire rated sheet rock at the headers, you're going to trap in the heat, which will do several things.
Whether the walls in the air gaps are burning or not, the moisture in the very long studs you used to get a nice ceiling height, will dry out very quickly and warp, torque, and possibly split. This will cause mechanical stress to the 5/8" fire rated sheet rock you have attached at the headers, thus fracturing it, and the heat will then blast it upwards right into the attic.
The heat that collects at the fire rated sheet rock will also cause the sheet rock itself to become more brittle, thus weakening it further, accelerating the splitting, tearing etc when it gets torqued when the heat warps the walls.
I'm not disagreeing with your fire inspector's requirement, he's merely following the law, but its an incomplete request. The fire rated headers by themselves don't buy you anything but compliance. They need to be supported properly, AND the air chambers between the rooms need to be sealed off as well, so a fire can't draw more oxygen.
I say this has a former, 7 year volunteer fire fighter, not as a hobbiest musician and a friend.
Fires can get so hot that asphault shingles can get goey and disintegrate. I've seen soldered copper piping pull apart from the heat, as the water inside steams away from the heated area an the solder melts. I've seen vinyl skylight frames melt and the glass comes in, oozing from the ceiling light some kind of alien science fiction movie.
I won't even get into car fires.
