wes480
in the other digital thread, sjoko2 said
"lets put it in the easiest way: "therein lies the summing problem" This is not just a problem with Pro Tools, most DAW software has a same or similar problem. When tracking with a DAW, always consider it as NOT having a level control option at all, and you'll be fine.
I first discovered this problem years ago when I was wondering why one session I had recorded using a Neve Legend console as a front end, going through good A/D converters straight into Pro Tools, sounded great (and I mean.... GREAT), and a subsequent session I did using the same gear, same artist, sounded considerably less.
The only difference was that in the first session I had not touched the faders.
A subsequent test proved this to be the definite problem / answer.
Please note that, yes, the summing problem does exist. Don't overestimate it though. If, as I had said to many times, you use accurate clock and good converters, you have won the biggest part of the battle. "
I am wonder about how my situation applies to this. I have an AardvarkQ10, where the preamps are all built into the breakout box, and the "mixer" is totally software, controlled by Aardvarks Drivers. Can anyone guide me on if I am somehow getting a much worse sound than i could be? And any more information on "summing" in general...I am confused.
