Monitor Terms??I dont understand!!
  • Thread starter Thread starter stoctony
stoctony
I have been shopping for monistors for some time now. 300$ will probably be my price range. So any good advice will help on that. But I keep hearing the three same terms come up. Tuned/active and passive. WHAT DOES IT ALL MEAN?????. I am recording solo acoustic from a behringer 2024FX. (dont say it i like behringer) No preamp yet that is to come. You guys have never let me down so far. Thanks in advance
stoctony
Tuned refers to ported speakers. Ports are used to extend bass response. The disadvantages are overall tightness, and port noise. Not many sealed boxes these days. The location of the ports can be an issue too. If they're on the back, and you have 'em close to the wall it can do funky things to the response. If they're on the front the port noise will be more noticeable.
Active means the speakers have amps built-in. This can be an advantage if space is an issue. The general consensus is that passive monitors will sound better if you have a good powerful amp to drive 'em.
Thanks Mbrane. I feel really stupid now. That was pretty simple. But hey, now I know. Thanks again
Yo Stocktony! When I first started building my studio, I was building it to record a project CD, but the mixing and mastering were to be outsourced, which turned out to be a very good decision. So- I had to cut a few corners, and I cut some of them on the monitor chain, figuring if I was going to track it, not mix it, I needed good mics, preamps, and instuments more than good monitors. That was also true. But, I needed to have something to listen to the music with, so I bought a pair of M-Audio SP5B's, which were the forerunner of the BX5's. They actually work pretty well, but for reasons I did not understand, the bass ports are in the back, so if you want to hear the bass, you have to walk around behind them, or put a hard reflecting surface, like plywood behind them.
Later, I found out that the SP5B's, and for that matter, the SP8B's (same deal with 8" drivers) were made to work with a powered subwoofer (I forget the number now). In any event, the new designation is BX5 and BX8, and the subwoofer is designated SBX. Well I learned to mix with these little bass-weak puppies, and they have served me rather well. About 6 months ago, I added the SBX sub ($500 list, $400 street price, GC sold it to me for $300 new) and Hola! I have bass, and can adjust it.
Most people on this board will recommend passive monitors, but the price of a good poweramp adds quite a bit to the budget. My recommendation is that you get a set of BX8-s if you can swing the money, and a set of BX5's if you can't. When the money becomes available later, add the SBX sub. Remember that the important thing about monitors is not whether they sound good. It's whether they will transmit the information to you that you need to make mixes that sound good on a home stereo or in a car. Monitors are built to reveal the sounds in music that suck- noise, hum, phase distortion, clipping.
They are not built to fill a room with sound. They are built to fill 2 square feet with sound. In the end, once you adapt to them, you can make good mixes with a pair of BX5's. Just remember that you will have a tendancy to turn the bass up too much, because the bass response of the monitors is weak, and when you play it back in the car, you may find that the bass blows your head off.-Richie
LOL! Don't be afraid to ask stupid questions. They're better than stupid mistakes! ;)
The smaller the speaker, the higher the roll-off point of the bass response. That's just the laws of physics. Small speakers that seem to have lots of bass (like Bose) use sonic trickery to fool your ears into thinking there is bass there that really isn't. This is no good for monitoring purposes.
Setting up a sub with small monitors can take a bit of tweaking, but can help your mixes to translate better on similar setups like home theater/car stereos.
