Chili
Site Moderator
I'd like to build a box that will allow me to select and route from multiple sources to multiple monitors. Plus, have two or three headphone amps with individual source selectors.
The first source is XLR from my D/A, the second is 1/4 unbalanced from my mixer and the last is the 3.5mm from the computer soundcard. I have two sets of monitors, the first uses XLR balanced, the other is 1/4 unbalanced 2.1 bookshelf type.
I expect to only choose one source and one monitor at a time and not have any kind of complicated routing. I'm thinking I can just straight wire these without any active electronics. Am I correct?? Do I need transformers to match up between unbalanced and balanced sources and loads????
To add headphone amps, are there any with Hi impedance inputs so they don't load down the signal going to the speakers??
Does anyone know of a supplier for cheap 1U chassis'???
Thanks much.
Thanks much.
