apl
Stand Up Comity
Anybody using a PODxt Live in a live setting? What do you do for monitoring and feedback?
notCardio said:how do you GET feedback if you're not using an amp.
notCardio said:I'm assuming you're talking about running the POD through a PA, not through a power amp, otherwise you wouldn't be asking those questions, right?
I would think that if the PA provides you with traditional stage monitors, that could be added to the mix. If not, you could take a direct out off the board and run it through a small amp (like your Line6) just for yourself, but then maybe lugging the amp around is what your trying to avoid by going with the POD.
You could use those vicegrips you call headphones to monitor, but then we can't have you lookin' dorky with your head turning blue in front of the congregation now, can we?
I guess it all boils down to what the monitor situation is on your PA.
Just break down and buy the Marshall stack and leave it at church.![]()
apl said:Yeah. The cab/power amp makes sense.
I don't play at church. I was just wondering how people who uses Pods, V-Amps, and ToneLabs, etc., live.
Farview said:If your band has in-ear monitors, none of this is a problem.
notCardio said:Oh, they've heard you sing, then.![]()
You would need an e-bow. You would also have problems getting controlable feedback out of floor wedge-type monitors. Feedback has a lot to do with the tone you are getting- the soundguy has 100 ways to louse that up and about 2 ways to make it happen. You are better off with a power amp/ speaker. I've never tried it, but a keyboard amp might work in this instance.apl said:How would you get guitar feedback if you wanted to cover I Feel Fine?
apl said:Anybody using a PODxt Live in a live setting? What do you do for monitoring and feedback?
Farview said:It gets confusing. If you are using a power amp and guitar cabinet, you would need to feed the FOH a signal with speaker simulation while sending your cabinet signal without speaker sim. Powered monitor or keyboard amp, both signals need speaker sim.
HAHAHA!TexRoadkill said:If you use the speaker simulator on a cab will the irony blow the speaker?
JCM900 said:Has anyone noticed that real musicians use real amps...
and only modeling musicians use modeling amps?
