N
nettech
This thread is for the ones of us who have Model 80's, R8's, A8's or similar decks and have diagnosed and repaired them. Tell what went wrong, and what you needed to do to fix it. I'll start off with a quick & simple one:
Symptom: A Model 80, in play or record mode only. Runs for a couple of minutes, a brief rumble (or hum) is heard thru outputs, transport stops, counter resets. Repeatable by entering play or record mode again. FF and Rewind not affected.
Solution: One of the diodes in the 2nd bridge rectifier on the power supply board was open. A scope reading showed 30hz ripple at 4V peak-to-peak.
Replaced whole bridge rectifier with a similar 1.4a/50V component from Radio Shack.
