Blue Jinn
Rider of the ARPocalypse
Working on a project where space (and cost) are major factors. Found some great projects at tonepad.com, which are mostly guitar effects. I am wanting to put these together with a set of preamps all in one small box. Therefore, I need everything to be line level. Using this as an example:
http://www.tonepad.com/getFile.asp?id=121
From what I know (which isn't much):
I need to adjust the input and output impedance to work with the other line level gear. (10-50k input impedance, as low as possible output impedance.) I should increase the supply voltage to give the unit greater headroom.
I should be able to a change the input resister to something like 10k-50k to lower input impedance (or perhaps a 10k-50k pot for an input level control)
I should eliminate the output pot to reduce the output impedance, or replace with a smaller resistor and/or a Jensen output isolator (JT-OLI-3).
I should be able to increase the operating voltage to 12-15v.
Am I right?
Thanks
Am I right?
Thanks
