Steenamaroo
Hey guys,
I've had threads about this before and never quite got to the bottom of it.
I have simplified it to some extent but I'm hoping someone can put this to bed once and for all.
What I did.
I modded my oktava mk219s. Removed the metal barring across the grills, removed the grills, separated them and put one layer back into the mic.
I made sure to sand down the surface that meets the grill, cleaned any glue off the grill, and used a conductive glue.
I read <3ohms from any point on the grill to pin1. It's a nice clean job. No breaks, no gaps.
The old problem.
The mics pick up what sounds like mains hum from my body which can only be completely eradicated by touching the mic shield/grill/etc.
Say i set the mic on my knee, or hold my hand close to the grill, I get this hum.
If i touch the grill, it's stone dead and everything sounds great.
The problem only occurs on laptops. My desktop with motu 828 (mains powered) is fine.
It all started on a dell vostro laptop with mbox. After a while i put it down to the laptop because i read about the floating ground of the laptop causing problems with audio/video outputs etc.
The current problem.
Now I have a macbook pro and a presonus firewire interface and have the same problem.
On the dell i made a cable that manually grounds the laptop chassis to mains earth which solved the problem, but on the macbook that's not happening.
IF i completely unplug the macbook PSU then interference isn't picked up from my body but there is still a constant faint hum that touching the grill doesn't fix.
I wanna work out why the mic is susceptible at all.
The plan.
Anyway, to cut to the chase, I'm thinking about completely re-grilling the mics with new grills but i don't see the point in making the same mistake again (if indeed i did make a mistake), so I'm hoping someone can offer advice here.
I see some guys with the mk319 mod using brass grilles, but then i see others using one layer of the stock grille.
Does it make a difference?
Things I've ruled out.
I'm not hearing the noise of something in the room, like fan or light dimmer or anything.
I've tried different rooms, different mains sockets, even different houses.
This doesn't happen with other stock condenser mics.
It can't really be a ground loop because even manaully tieing everything to mains ground doesn't help.
I've read everything i can about this mod and the only people who had problems hadn't grounded the grill to the body properly, but I've even reglued the grills recently and made certain they were continuous with the mic body.
IDK, the only reason i bought all this crap is so i record mobile. Like, just take my bag and go. anywhere kinda thing.
Now if I wanna use my oktavas I have to bring some mains powered interfaces or whatever just to get around this hum.
It kinda defeats the purpose.
Thanks in advance all.
What I did.
The old problem.
The plan.
