elenore19
Slowing becoming un-noob.
Would this make the sound quality worse? or is it any way just a general bad idea?
Thanks.
-Elliot
Thanks.
-Elliot
I think maybe he might just be using the mixer in this case as a preamp to have line level outs to plug his monitors into.
In this case, elenore, your sound card should have a stereo speaker out (the green jack on PC sound cards). You can use that just fine. You'll be limited to the sound quality of the sound card, but within that limitation it'll work OK. If you already have your computer speakers plugged into that and you want to leave those plugged in, you can get a stereo splitter plug (basically a little stereo Y plug) that will let you use both simultaneously. On the side going to the mixer, you'll need an additional adapter that will change that 1/8" stereo jack to L/R RCA or 1/4" jacks (depending upon where you're going on the mixer.)
Note, though, that because this will be an unbalaced line running from your computer to your mixer, wit will be subject to possible electrical or RF noise from things like transformers and CRT monitors. If you have a noisly line, try running it away from such noise sources, and perpendicular to and not parallel to AC power cords where possible to minimize such noise.
G.
Yeah, I thought of that after I asked the stupid question.I'm using a laptop, so I can't upgrade the soundcard.
Also I'd go into the mixer through the rca inputs. the red and white ones. I'm using a short little 3 foot adapter cable to do it.
I'm using the mixer to control the volumes on my monitors.
Yeah, that's fine. That's exactly how I wire up my portable DJ system. Green out of the laptop to an adapter cable that has the stereo mini plug on one end and the RCA plugs on the other, with the plugs going into the Tape In jacks on the mixer.I'm using a laptop, so I can't upgrade the soundcard.
All of my recent mixes have been on laptop, and they don't sound too horrid. I don't have monitors, though...Yeah, that's fine. That's exactly how I wire up my portable DJ system. Green out of the laptop to an adapter cable that has the stereo mini plug on one end and the RCA plugs on the other, with the plugs going into the Tape In jacks on the mixer.
No the sound quality won't be that of a top-grade studio - I wouldn't recommend mastering a commercial-bound CD on it - but for home recording mixing on the laptop it'll do just fine.
G.
Yep. Sure, the DACs on laptop soundcards are not meant for real fine-grain monitoring, but there's no reason one can't make decent home mixes using the output of such a sound card to monitor. I've done it plenty in the past, and so have a hundred people I know. Well, now let's make that a hundred and oneAll of my recent mixes have been on laptop, and they don't sound too horrid. I don't have monitors, though...![]()
I agree completly for several reasons. I just wanted to confirm to him that using the card for monitor out, while not ideal, is certainly doable.Not denying that cause I started out like that and I had some pretty good mixes, those mixes actually got me a job at a studio. They were blown away I could mix like that with what I had. But what I was saying was if you had a little money to spend I would go with a interface.
So I take it that even though you are not recording with it, getting an interface to replace the stock soundcard for mixing with monitors is the way to go? It's funny that all I have ever used were headphones to mix because I have never owned a real set of monitors, and when I used computer speakers (Bose Companion II ) I didn't like the bass response so I went back to cans. I never even thought that there was actually something more that I would need in between the monitors and the computer.Not denying that cause I started out like that and I had some pretty good mixes, those mixes actually got me a job at a studio. They were blown away I could mix like that with what I had. But what I was saying was if you had a little money to spend I would go with a interface.
Actually, I take some of that back. I figured there had to be something in there, but I was thinking more along the lines of an amplifier because most of the monitors that I had seen needed an amp to drive them.So I take it that even though you are not recording with it, getting an interface to replace the stock soundcard for mixing with monitors is the way to go? It's funny that all I have ever used were headphones to mix because I have never owned a real set of monitors, and when I used computer speakers (Bose Companion II ) I didn't like the bass response so I went back to cans. I never even thought that there was actually something more that I would need in between the monitors and the computer.
I gotta give the OP some rep for opening my eyes...![]()
You might want to look into getting either a usb interface, or if you have firewire something to the effects of the mbox, tascam 428 (if they still make them) if you want a mixer with faders or the tascam 122 , that way it is something that takes the place of a soundcard and will give you a better quality sound when mixing. I use a laptop but I use the Mbox
Did the firewire come with a CD? Perhaps it's just a matter of installing the drivers?Here's the dilemma.
I have an Alesis Firewire mixer. Works great on my Macbook Pro. But the program that I want to mix with I only have for windows. I have bootcamp and everything so I have XP on the same computer. But the mixer doesn't work with the XP side of my computer. I've called alesis and apparently it's a problem that shouldn't happen and they want me to send it in. Not worth it for me.
So there you have it.
I'll definitely try out this setup since you guys seem to think it will be alright.
