Hi all! I'm new here with a little problem: I'm currently recording with my band. What we use: an Alesis ADAT Type II XT20 and a Mackie 1202 VLZ console.
I put all effects directly while recording each track because we don't own enough material to add effects on each track while mixing down. The drum is a V-Drum from Roland so I plug it and record it directly (don't know exactly which effects...), as well as the bass through a direct box with a little bit of chorus, reverb (not much) and a compressor / noise gate. The guitar goes through a Boss GX700 effect module and then a monitor, and is the only instrument to be miced (Shure SM58). Some keyboards arrangements will be added later.
Now for a few weeks I try to record vocals but can't get a good sound. The recording of all instruments sounds very clear, but the voice always sounds a little bit "far" or "dead" (I'm sorry English is not my main language so I try to express it as best as I can , but still it is as clear or loud as the rest, it just does not have the same feel... It is like to voice is besides the rest.
What I have done and used:
-AudioTechnica 4033a microphone w/ popper stopper
-I run the line through a compressor/noise gate (PreSonus) set as a limiter
-I use my guitar effect module (Boss GX700) to add some delay (someone told me to add this effect... wihtout effects the vocals sounded very "raw")
My recording level is similar to that of the other instruments (around -4dB on my Alesis), I played with the EQs... all of the music sounds "together" and the vocals sound "apart". Any tips or tricks??
TIA, sorry for such a *long* message
Wanderer
Wanderer
